Print Page | Close Window
LISP DOES NOT WORK WITH AUTOCAD 2007 AND 2008
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=208
Printed Date: 29.Oct.2026 at 08:06
Topic: LISP DOES NOT WORK WITH AUTOCAD 2007 AND 2008
Posted By: YDYD
Subject: LISP DOES NOT WORK WITH AUTOCAD 2007 AND 2008
Date Posted: 24.Oct.2007 at 08:47
hi. there
I have got lisp routine wich i used for many years staring with autocad R2000 but it does not work with R2007 and R2008,
help please.
;LTXT.LSP      Linetype Generator     (c)2001, Darren Marker
(defun
     C:LTXT ()
  (setvar "cmdecho" 0)
  (setq V:CLAYER (getvar "clayer"))
  (setq V:EXPERT (getvar "expert"))
  (if (not V:LINET)
    (setq V:LINET "XX")
  ) ;_ end of if
  (setq V:LINET_X
         (getstring
           (strcat
             "\n \n \nEnter line text: <"
             V:LINET
           ) ;_ end of strcat
         ) ;_ end of getstring
  ) ;_ end of setq
  (if (/= V:LINET_X "")
    (setq V:LINET (strcase V:LINET_X))
  ) ;_ end of if
  (setq V:LINET (strcase V:LINET))
  (LT_MAKER)
) ;_ end of defun
(defun
     LT_MAKER ()
  (setvar "expert" 4)
  (setq V:LINET_L (strlen V:LINET))
  (setq V:LINET_W (rtos (* V:LINET_L 0.1) 2 1))
  (setq V:LT_FILE "c:\\temp\\lt_temp.lin")
  (setq V:LT_VAR1 (open V:LT_FILE "w"))
  (setq V:LT_TEXTL1
         (strcat
           "*" V:LINET "," V:LINET "----" V:LINET "----" V:LINET "----"
           V:LINET
          ) ;_ end of strcat
  ) ;_ end of setq
  (setq V:LT_TEXTL2
         (strcat
           "A,3.0,-0.2,["
           (chr 34)
           V:LINET
           (chr
             34
           ) ;_ end of chr
           ",SIMPLEX,S=0.1,R=0.0,X=-0.1,Y=-.05],-"
           V:LINET_W
         ) ;_ end of strcat
  ) ;_ end of setq
  (setq V:LT_VAR2 (write-line V:LT_TEXTL1 V:LT_VAR1))
  (setq V:LT_VAR3 (write-line V:LT_TEXTL2 V:LT_VAR1))
  (close V:LT_VAR1)
  (command "-linetype" "l" V:LINET V:LT_FILE "")
  (setvar "expert" V:EXPERT)
  (command ".celtype" V:LINET)
  (princ
    (strcat
      "\n \n \nCurrent Layer -"
      (getvar
        "clayer"
      ) ;_ end of getvar
    ) ;_ end of strcat
  ) ;_ end of princ
  (princ)
  (princ
    (strcat
      "\n \n \nCurrent Entity linetype set to:"
      V:LINET
    ) ;_ end of strcat
  ) ;_ end of princ
  (princ)
  (setq V:PNT1 (getpoint "\nPick start point:"))
  (command ".line" V:PNT1)
  (while
    (setq V:PT
           (getpoint
             (getvar "lastpoint")
             "\nNext point
             or <Return to
             terminate>:"
           ) ;_ end of getpoint
    ) ;_ end of setq
     (command V:PT)
  ) ;_ end of while
  (command)
  (command)
  (setvar "celtype" "bylayer")
  (princ)
  (princ
    "\n \nLine-Text terminated.  Linetype set to
             BYLAYER:"
  ) ;_ end of princ
  (princ)
) ;_ end of defun
(princ)
(princ " Line-Text Loaded...")
(princ)
(princ
  (strcat
    "\n \n"
    (chr 34)
    "LTXT"
    (chr 34)
    " to
             execute:"
  ) ;_ end of strcat
) ;_ end of princ
(princ)
Posted By: dmarker
Date Posted: 08.Apr.2008 at 22:03
Hello.
I've tested the routine in AutoCAD 2008 and with a minor modification, I got it working as you are used to.
The change is in this line ",SIMPLEX,S=0.1,R=0.0,X=-0.1,Y=-.05],-"
Simply change the "SIMPLEX" to "STANDARD" and it should work great.
If you still have issues, feel free to contact me.  I can send you the .LSP file directly.
When I wrote this little routine, it filled a huge gap in my AutoCAD daily tasks.  I'm happy that it's something that you've been using for years and want to continue.
Best regards,
Darren
