Print Page | Close Window
Layer Control
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=210
Printed Date: 21.Oct.2026 at 05:08
Topic: Layer Control
Posted By: MARPOW
Subject: Layer Control
Date Posted: 25.Oct.2007 at 14:33
Eventhough we have visretain on viewport layer states are not being retained. Any clues or things to try?
Posted By: iDraft
Date Posted: 31.Oct.2007 at 06:52
well what changes did you make to the viewports? are you using freeze/thaw on/off and did you accidentally change the whole drawing please give more info.
iDraft
Jesse Davis
mailto:idraft4you@gmail.com - Send Me an Email
Subcontract your Civil and Survey Drafting
Posted By: MARPOW
Date Posted: 31.Oct.2007 at 14:08
We are going into the viewport and freezing layers and even with visretain on the frozen layers are back on when the drawing is reopened.
Posted By: iDraft
Date Posted: 31.Oct.2007 at 17:57
is the file read only?
iDraft
Jesse Davis
Posted By: MARPOW
Date Posted: 01.Nov.2007 at 12:08
None are read only.
Posted By: iDraft
Date Posted: 01.Nov.2007 at 17:27
and your visretain is set to 1?
you are using xref's correct?
iDraft
Jesse Davis
Posted By: MARPOW
Date Posted: 01.Nov.2007 at 18:18
visretain is set to 1 and we are using xref's
Posted By: iDraft
Date Posted: 01.Nov.2007 at 19:03
well how do you have your xref's inserted, if they are attachements, and you have multiple nested xref references then the layers can get kinda funky. using overlays should fix the problem.
iDraft
Jesse Davis
Posted By: MARPOW
Date Posted: 01.Nov.2007 at 19:13
Thanks for your suggestion, but we are still having the problem, even with no nesting.
Posted By: iDraft
Date Posted: 01.Nov.2007 at 21:26
this intrigues me can you send me a copy of the file to look at?
iDraft
Jesse Davis
