polyline / boundary
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2215
Printed Date: 05.Sep.2026 at 00:02
Topic: polyline / boundary
Posted By: prakash_anu
Subject: polyline / boundary
Date Posted: 16.Jul.2009 at 17:39
how to convert whole drawing in to boundary or close polyline with single command. eg. if i have lay out of residence drawing then each wall is converted in close polyline or boundary how i going to attch auto cad file in this forum so it is easy to explain?
Posted By: msplcdykee69
Date Posted: 17.Jul.2009 at 04:14
You can use the PE command (Poly Line Edit) type M for multiple lines select all lines you wish to close then follow the command prompt. Or you can select all lines (If they are already plines then from the properties window down at the bottom select close and "yes" that should close them provided that they are continuous lines with only one break point. If not PE command is the way to go to join them.
------------- Engineering Manufacturing Medical Cables/Adjunct Instructor Engineering Graphics/Engineering Computations and Careers
msplcdykee69@yahoo.com
Shawn
Date Posted: 17.Jul.2009 at 10:05
this is nice one but my qurry is diffrent i just mail u autocad file @ you mail so it is easy to understand. thank you
Date Posted: 18.Jul.2009 at 19:55
i want to make boundary of all dawing in on single selection of all outline
Posted By: gizmeau
Date Posted: 28.Jul.2009 at 18:54
