Print Page | Close Window
remove lines from a 3d solid
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=225
Printed Date: 28.Oct.2026 at 00:05
Topic: remove lines from a 3d solid
Posted By: scottnjayme
Subject: remove lines from a 3d solid
Date Posted: 01.Nov.2007 at 18:28
When i create a 3d solid in autocad 2008 that has a radius or filleted surface, a line is created which apparently marks the tangent point of the radius. i want to remove this line when i change the visual style to 3d hidden.
scottie2hottie
Posted By: Vladimir Michl
Date Posted: 02.Nov.2007 at 14:51
You mean the DISPSILH variable?
Vladimir Michl
//CADs.cz" rel="nofollow - //CADs.cz , https://www.linkedin.com/in/vmichl/" rel="nofollow - LinkedIn
Date Posted: 02.Nov.2007 at 18:40
Im not sure what DISPSILH does exactly. the help menu didnt really explain. Is there a way to post a picture of what i want on here? When i use the solprof command to create a 2d image from my 3d model, the third command prompts is delete tangential edges. deleting these tangential edges creates a correct orthographic projection. i want my 3d model to appear without the tangential edges. I think these lines are also called tessellation lines.
scottie2hottie
