Export pdf changes layer order
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2308
Printed Date: 06.Sep.2026 at 21:58
Topic: Export pdf changes layer order
Posted By: christo999
Subject: Export pdf changes layer order
Date Posted: 14.Aug.2009 at 13:45
Using the exportpdf-command in AutoCAD 2010 I noticed the order of layers has changed comparing the order in model-space, paper-space or pdf's generated by the "normal" plot command as I normally use like cutepdf.
In my case I'd like to have all my layers in front of the background image. This is correct within AutoCAD (modelspace & paperspace) and remains correct when printed by cutepdf. However I'd like to use the exportpdf-command to include the possibility to switch layers on and off in my pdf-file.
Is there someone who has an idea how this can be fixed ?
Regards,
Posted By: Vladimir Michl
Date Posted: 20.Aug.2009 at 11:26
This is fixed in the SP1 (Update 1) - see Download.
------------- Vladimir Michl (moderator) https://www.linkedin.com/in/vmichl/" rel="nofollow - LinkedIn , Autodesk Expert Elite
