Print Page | Close Window
mtedit orientation/rotatio problems during editing
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2469
Printed Date: 04.Sep.2026 at 22:51
Topic: mtedit orientation/rotatio problems during editing
Posted By: DH002371
Subject: mtedit orientation/rotatio problems during editing
Date Posted: 24.Sep.2009 at 19:30
I am using Autodesk Map 3D 2007.  When I execute the mtedit command and select a box of mtext that is oriented in a horizontal direction, it automatically rotates it 90 degrees clockwise while in the edit mode.  If I make changes and select OK, it does not put it back in the correct orientation.  I have to select it then change the rotation in the properties dialog box back.  It does not consistently do this but probably does it 8 times out of 10 and makes it difficult to make the changes correctly the first time.
Thanks for any help!
Denise    Confused
