Print Page | Close Window
Cant Wblock or Copy and Paste
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2472
Printed Date: 21.Oct.2026 at 10:22
Topic: Cant Wblock or Copy and Paste
Posted By: the si
Subject: Cant Wblock or Copy and Paste
Date Posted: 25.Sep.2009 at 11:38
Hi guys
I really need some help. I have Autocad 2000. When I go to wblock something, I go through the normal procedures then I click OK the block does not get created. Nothing shows up in the file I selected. Copy and paste isnt working either. This is happening with drawings that I am getting from one person, I think they use 2006lt. With other drawings its working fine.
I have used many versions of cad for years so its nothing obvious like locked layers or the way im wblocking.
Id be really grateful if anyone can help me? because this is a real painAngry when I want to copy frames etc.
Thanks
Posted By: p3.1416l
Date Posted: 25.Sep.2009 at 17:11
Hi, I think your problem will be solved as described in " /cadforum_en/qaID.asp?tip=5077 - Copy/Paste fails in a DWG2000 file saved from Hope it works
Less is more
Posted By: the si
Date Posted: 25.Sep.2009 at 23:44
thank you.
problem solved
