Print Page | Close Window
Error while opening a DXF file converted from PDF
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2612
Printed Date: 05.Sep.2026 at 19:32
Topic: Error while opening a DXF file converted from PDF
Posted By: saadicarnot
Subject: Error while opening a DXF file converted from PDF
Date Posted: 02.Nov.2009 at 11:27
I converted a drawing in PDF format to DXF by using Aide PDF to DXF converter. The file was converted but as I open the output in AutoCAD I get a following error:
DXF read error on line 2275.
Invalid or incomplete DXF input -- drawing discarded.
Press ENTER to continue:
I have used Aide output in Autocad before and there were no errors for those files. It gives the mentioned error for only few drawings which I recently wanted to use in my Layout. Any help would be great.
Thanks.
Best regards,
Saad
Posted By: CarlB
Date Posted: 02.Nov.2009 at 20:34
Don't know.  Some things to try:
-Contact Aide PDF or see if they have a website that discusses error messages or common problems
-Can you "audit" a dxf file?
-look on line 2275 and see if you can spot an error
-Rather than convert to dxf, convert to a tiff and insert it as an image
