Print Page | Close Window
[dxf] reading entities not used (can be purged)
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2626
Printed Date: 30.Sep.2026 at 05:05
Topic: [dxf] reading entities not used (can be purged)
Posted By: massimo_74
Subject: [dxf] reading entities not used (can be purged)
Date Posted: 04.Nov.2009 at 15:18
Hi,
I've a little problem reading DXF file with my own application.
In my program I see entities that in Autocad there is'nt, can be PURGED.
Reading che DXF file, how I can understand when a block (or entity) is not used (can be purged) and the i can leave invisible?
What is the attribute of an entity that can be purged, hw I can see in the DXF code?
Thanks,
Best Regards, Massimo.
Posted By: CarlB
Date Posted: 04.Nov.2009 at 19:58
I suppose if a Block can be purged, it can be found in the TABLES section, but not in the ENTITIES section if it has not been inserted.
Or...before making a dxf from AutoCAD, purge it first :)
