Print Page | Close Window
xref not binding
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2848
Printed Date: 05.Sep.2026 at 07:08
Topic: xref not binding
Posted By: COSMICBRAT
Subject: xref not binding
Date Posted: 09.Dec.2009 at 23:10
I've this msg came up..."At least one of the specified Xref failed to bid for unknown reason...."
I tried redoing the Xref (It's a base building dwg from an architect) but it's still doing that.
At this point I'm writing it off as Architect's dwg fault since I can't bind their original dwg.  I'm curious -- Any ideas of what could be the problem??
Posted By: CarlB
Date Posted: 10.Dec.2009 at 04:17
It could well be the architect's drawing, may have some objects created with an add-on like architectural desktop which can cause problems.
Posted By: tulip3D
Date Posted: 11.Dec.2009 at 16:02
Forget binding and all that fancy stuff, just open the architects dwg, sweep select the whole thing, copy to clipboard. now open up whatever drawing you want and hit paste clipboard. done. you could even create a group to manage the paste clip as an "exref" of sorts. If you have problems at that point, then you can more easily narrow them down.
