Print Page | Close Window
Activated pre-release Autocad 2008
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=286
Printed Date: 03.Sep.2026 at 19:11
Topic: Activated pre-release Autocad 2008
Posted By: ptota
Subject: Activated pre-release Autocad 2008
Date Posted: 26.Nov.2007 at 11:43
Good morning all,
i have a problem whit activation Autocad 2008.Cry
Trial version is expired and i have a new Serial number for registration, but after the installation i don't succeed in making to turn autocad 2008 to activate the product.
The visualized message is:
End of evalutation period
Sorry, this pre-release product has exipered
and the program him intrerrompe.
Can you help me?Big%20smile
Thanks
Posted By: catman
Date Posted: 30.Nov.2007 at 20:17
Hi
If you  have a new Serial number for registration you should be able to run the setup and set the serial,if not do a full un-install using a programme like (Your uninstaller ) this removes all the registery fields.
Then do a reinstall and load the serial on start up
Rgds
Pm Me if you need this uninstaller programme or help with  serial
Posted By: Vladimir Michl
Date Posted: 03.Dec.2007 at 18:48
Please contact your Autodesk reseller for license activation problems.
Vladimir Michl (moderator)
ARKANCE - https://arkance.world" rel="nofollow - https://arkance.world - Autodesk Platinum Partner
