Print Page | Close Window
Inventor-Autocad Linetype-Layer conversion
Printed From: CAD Forum
Category: EN
Forum Name: Inventor
Forum Description: Discussion about Autodesk Inventor
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2972
Printed Date: 29.Sep.2026 at 02:37
Topic: Inventor-Autocad Linetype-Layer conversion
Posted By: tulip3D
Subject: Inventor-Autocad Linetype-Layer conversion
Date Posted: 07.Jan.2010 at 14:40
Hello!
When I 'save as', then 'save copy as' in inventor to get 3D model views into dwg format, how can I preset inventor to convert all linetypes to the 0 layer in autocad?
Currently, when I open a newly created dwg file from inventor, theres all these bullsh!t layers created. I would like to avoid this.
Any suggestions would be great!
Posted By: tulip3D
Date Posted: 11.Jan.2010 at 16:19
you guys suck.
autodesk subscription center knows all:
The layer that objects are placed on is based on your Styles and Standards settings.
1.     Go to the Manage ribbon tab.
2.     Click on Styles Editor.
3.     Open the Object Defaults.
4.     Change the layer for each type of object you want to show on a different layer.
