Print Page | Close Window
Bring Text and Dimensions to Front
Printed From: CAD Forum
Category: EN
Forum Name: RSS Feeds
Forum Description: Automatic publishing of CAD information from other web sources
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3107
Printed Date: 17.Sep.2026 at 08:36
Topic: Bring Text and Dimensions to Front
Posted By: LTunlimited RSS
Subject: Bring Text and Dimensions to Front
Date Posted: 29.Jan.2010 at 11:58
I like to think I usually have a pretty good idea of when a certain feature or command was added to AutoCAD LT. But I was surprised to realize that today's tip has been around since as far back as AutoCAD LT 2005. Now I've learned my something new for the day!Anyway, this under-the-radar command is TEXTTOFRONT, and while it's under the Draw Order item on the Tools menu, it's not on any default toolbars or ribbon panels.Its purpose is simple: to grab all text objects and/or dimension objects in your drawing and bring them in front of all other geometry. If you plot with "lines overwrite" turned on, this provides a quick and easy way to make sure none of your annotations get obscured by other lines.(And if you're curious how I managed to track down the introduction date of this command, check out the excellent AutoCAD Command Reference at HyperPics.)
Go to the http://feedproxy.google.com/~r/LtUnlimited/~3/5NpHj0gy1po/bring-text-and-dimensions-to-front.html - original post...
http://ltunlimited.typepad.com" rel="nofollow - LT Unlimited - Autodesk blog by Kate Morrical
