Print Page | Close Window
3D Linetype Problem
Printed From: CAD Forum
Category: EN
Forum Name: Civil 3D, Map, InfraWorks
Forum Description: Discussion about mapping and GIS applications Map, Civil3D, InfraWorks, MapGuide and Raster Design
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3131
Printed Date: 29.Aug.2026 at 06:45
Topic: 3D Linetype Problem
Posted By: jite
Subject: 3D Linetype Problem
Date Posted: 03.Feb.2010 at 09:48
Dear All,
I have a linetype...that works...but I cannot assign it to a 3D Polyline....Well I can..but it doesn't show up on screen correctly (stays CONTINUOS)...Is this possible (assign linetype to a 3D Polyline)
Regard
jitendra panchal
jitendra
Posted By: CarlB
Date Posted: 03.Feb.2010 at 18:43
No, AutoCAD does not support 3d polylines displaying other than continuous.
So it's not just you :)
Posted By: Jan Peter
Date Posted: 09.Mar.2010 at 14:45
Hi there
I had the same problem. I contacted a woman who keeps a course in AutoCAD. She sent me a "solution" and then some, which reads:
Why won't my 3D polylines display a linetype?
3DPOLY's cannot contain arcs, display linetypes or show width or thickness.  However, you can assign a linetype style to a 3D polyline and it will retain the information.   Simply save the drawing, explode the 3D polylines before you plot (the LINES will display the linetype), then undo to restore the 3D polylines.
Why don't my splined polyline vertices go through the original vertices?
As you probably know, using the Spline option ofthe PEDIT command creates a splined polyline but the path of the spline does not run through the original control points. In contrast the spline created with the SPLINE command does run through thecontrol points and is the end result you want. Back on the negativeside the SPLINE command has an option to convert an existing polyline, but only one that has been splined. The converted spline is still not what you want.
So the best way with stock AutoCAD is to turn on the endpoint osnap,issue the SPLINE command and get starting picking points. ToolPac users will find Convert Polylines to Splines that will process a selection set of un-splined polylines and give you the results you want.
How can I draw a tangent line off an ARC within a polyline?
You may have noticed that when you go to the ARC mode within the PLINE command, the first and consectutive arcs are tangent to the previous segment.  To create a tangent line off the last segment, first press L for Line mode, then press a second L for Length.  Pick or enter a distance and the segement drawn will be tangent off the last arc.  Its the 2nd L that does the trick.
How can I convert R14 LightWeight Polylines back?
At the command prompt type CONVERTPOLY. This undocumented command built into AutoCAD R14 allows you to convert lightweight polylines to the old 'heavy' polylines, preserves arcs and polyline width. Some 'not so current' applications may require standard polylines.
Best regards, Jan Peter
Posted By: Rajashree
Date Posted: 29.Apr.2010 at 11:55
We at Dimension India(www.dimensionicad.com) use the following method to deal with 3D Linetype problems:
3D polylines can be assigned any linetype, but will only display as continuous.
One method is to copy each one in place to a different layer, then explode them all so that the linetypes will display. Then vary the layer visibility depending on whether you need the 3D component or the linetypes to display.
Another method... Just before you get ready to plot, save the drawing. Then explode the 3D polylines, then plot. The linetypes will show up. Then either quit without saving or UNDO.
I hope this will help u as well.
Thanks!!
