Dyn. Simulation - Boundary ignored
Printed From: CAD Forum
Category: EN
Forum Name: Inventor
Forum Description: Discussion about Autodesk Inventor
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3341
Printed Date: 15.Aug.2026 at 20:11
Topic: Dyn. Simulation - Boundary ignored
Posted By: PavolK
Subject: Dyn. Simulation - Boundary ignored
Date Posted: 11.Mar.2010 at 20:24
I have created simple 4bar linkage for mountain bike with coil shock in there. There is a mate constraint between axes of shock piston and shock body. In Dyn.Sim. environment I specified -76mm value for Position of Translational DOF of this constraint. However, if I specify 0mm for Max. value in Boundaries for this DOF, it is ignored at all. Simulation goes beyound this point pushing the coil unrealistically. If there was possibility to specify stroke of the coil spring of Spring Joint I wouldn't have to solve things like this.
Also, I have one more question. Why does the Images value on Simulation Panel make simulation to perform differently for different Images values? If I don't change Final time value on Simulation Panel, why is simulation performed differently for Images=8 and Images=100 ? It's weird.
O, and I'm using Inventor 2008 Professional. If these are known defects, are they solved in Inventor 2010? Thanks for any help. Pavol
------------- Pavol Kianicka
Posted By: PavolK
Date Posted: 15.Mar.2010 at 09:16
No one has experiences with DS in IV2008? The original Inventor 2008 help and tutorial files are not very helpfull with this as they often declare what is intuitively clear.
Posted By: tulip3D
Date Posted: 15.Mar.2010 at 18:13
hahaha your right about that! Help is always ready to show you what you already know. I would check out video tutorials on youtube...or simply widen your search across the net. Either way, good luck!
