No Ribbon on AutoCAD on dual monitors
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3404
Printed Date: 05.Sep.2026 at 09:55
Topic: No Ribbon on AutoCAD on dual monitors
Posted By: tony.anderson
Subject: No Ribbon on AutoCAD on dual monitors
Date Posted: 22.Mar.2010 at 10:43
Hi all
I'm doing some testing running AutoCAD on Citrix, and
seem to be having a small problem, with the ribbon not appearing on a
PC running dual screens, AutoCAD runs fine on a single screen but not
on dual screen, any idea of a fix ?
Posted By: bcbenton
Date Posted: 22.Mar.2010 at 15:40
I've had issues accessing machines that had dual monitors on it with Citrix. I think there is a setting somewhere, but by default it only uses one screen, the main screen. If the ribbon or any other panel/window/dialog box is on the second screen, it won't be seen. It will have to be moved by the user.
------------- For AutoCAD Tips & Tricks
http://cadablog.blogspot.com/ - CAD-a-Blog
Date Posted: 22.Mar.2010 at 16:23
Hi
Was this the reg change you were talking about
[HKEY_LOCAL_MACHINE\SOFTWARE\Citrix\CtxHook\AppInit_Dlls\Multiple Monitor
Hook]
"DefaultHooks"=dword:00000801
Thanks for your help
