Print Page | Close Window
AutoCAD 2011 Feature Tips Tricks ~ Drawing Background and UCS Changes
Printed From: CAD Forum
Category: EN
Forum Name: RSS Feeds
Forum Description: Automatic publishing of CAD information from other web sources
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3587
Printed Date: 20.Apr.2026 at 19:15
Topic: AutoCAD 2011 Feature Tips Tricks ~ Drawing Background and UCS Changes
Posted By: BetweenTheLines
Subject: AutoCAD 2011 Feature Tips Tricks ~ Drawing Background and UCS Changes
Date Posted: 07.Apr.2010 at 17:11
Upon starting http://www.autodesk.com/autocad - AutoCAD 2011 you will immediately notice a few changes in the default settings. One is the background is now a pleasant dark blue and the old point grid is now replaced by a engineering graph paper-like grid lines.
The default modelspace background colors changed from dark gray to dark blue.
Old 2D modelspace background grey RGB 81,93,97
Old 3D modelspace background RGB 36,47,61
The new consistent background RGB 33,40,48 for both 2D and 3D modelspace.
 AutoCAD 2010 2D modelspace background  RGB 81,93,97 AutoCAD 2010 2D modelspace background  RGB 36,47,61
AutoCAD 2011 RGB 33,40,48
The Layout paper color are the same as white but a slight difference in shade of grey background.
The old dot grid has been replaced by a new engineer graph paper like grid.
 AutoCAD 2010 Grid AutoCAD 2011 Grid
The UCS with the grid on will show a green line for the Y axis and a red one for the X axis.
AutoCAD 2011 background grid and UCS axis colors
The 3D UCS no longer has those cones on the end of the axis which always reminded me of the cones they place over a dog’s head to prevent it from licking wounds.
Dog Cone
AutoCAD 2010 2D UCS AutoCAD 2011 2D UCS
image image
Cursor also has the colors matching the axis.
If you have not tried AutoCAD 2011 yet, you can download a free AutoCAD 2011 30 day full trial from http://www.autodesk.com/autocad - http://www. http://www.autodesk.com - autodesk .com/autocad
Cheers,
Shaan
http://feeds.feedburner.com/~ff/blogs/btl?a=T5jHsReJ1OE:IR07zwSeA4o:yIl2AUoC8zA"> http://feeds.feedburner.com/~ff/blogs/btl?a=T5jHsReJ1OE:IR07zwSeA4o:qj6IDK7rITs"> http://feeds.feedburner.com/~ff/blogs/btl?a=T5jHsReJ1OE:IR07zwSeA4o:V_sGLiPBpWU"> http://feeds.feedburner.com/~ff/blogs/btl?a=T5jHsReJ1OE:IR07zwSeA4o:sHskjighKVI">
Go to the http://feedproxy.google.com/~r/blogs/btl/~3/T5jHsReJ1OE/autocad-2011-feature-tips-tricks-drawing-background-and-ucs-changes.html - original post...
http://autodesk.blogs.com/between_the_lines/" rel="nofollow - Between the Lines - Autodesk blog by Shaan Hurley
