Print Page | Close Window
nuts and bolts
Printed From: CAD Forum
Category: EN
Forum Name: Inventor
Forum Description: Discussion about Autodesk Inventor
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3619
Printed Date: 10.May.2026 at 14:31
Topic: nuts and bolts
Posted By: chrismof
Subject: nuts and bolts
Date Posted: 13.Apr.2010 at 23:11
Could anyone please advise me if there is a library in autodesk inventor 2010 wher you can find nuts and bolts
Thanks
Chris
Posted By: backinwi
Date Posted: 15.Apr.2010 at 16:50
Yes but it needs to be loaded at install (Content Center). If loaded you should be able to start a new Assembly. The first icon in the ribbon is Place. If you hit the drop down arrow you should have an option for Place From Content Center. From there you have a wide range of standard hardware components.
Let me know if you dont have content center...
Posted By: chrismof
Date Posted: 19.Apr.2010 at 08:51
Thanks for the help with the contents centre managed to find it.
Posted By: KobusErasmus
Date Posted: 19.Apr.2010 at 19:34
Try using the design accelerator for bolting, its quicker.
Kobus Erasmus
Piping design draughting
Contract draughting
Posted By: chrismof
Date Posted: 28.Apr.2010 at 13:39
Thanks I'll give that a try
