Print Page | Close Window
Inventor Fusion Sandbox Version Now Available
Printed From: CAD Forum
Category: EN
Forum Name: RSS Feeds
Forum Description: Automatic publishing of CAD information from other web sources
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3731
Printed Date: 18.Apr.2026 at 08:45
Topic: Inventor Fusion Sandbox Version Now Available
Posted By: AliveInTheLab
Subject: Inventor Fusion Sandbox Version Now Available
Date Posted: 04.May.2010 at 04:00
Try Inventor Fusion Technology Preview in a sandbox When you think of software as a service, a few technologies come to mind: Remoting: This is the ability to run an application remotely. This is something that you have seen with Project Twitch where you can try AutoCAD, Inventor, or Revit without installing them. You run them using your browser. Instead of your own computer, the applications run on remote servers that you are connected to via the internet. Streaming: Streaming is the ability to install an application little by little. You download and install just enough of the application to get you started. As you use the application the rest is downloaded and installed. The download and install can come from a remote server or a USB key connected to your computer. The advantage of streaming is that you do not have to download the entire application and install the entire application before being able to use it. Unlike with remoting, the application does run on your local computer instead of a remote server. Sandboxing: This is a relatively new technology that you might not be familiar with yet. Think of a child's sandbox. It is a safe place to play that is sectioned off from the rest of the backyard. Now think of how installs work. Installers place files in several locations on your computer and make numerous registry updates to allow the application to run. Imagine if all of that file and registry goop were condensed into one file - a sandbox. Autodesk Labs is offering a preview of a sandboxing technology for the Inventor Fusion Technology Preview. You download InentorFusionTP31.exe and run it. No install required. The Inventor Fusion Technology Preview runs on your machine as if you had installed it, but you get to skip that step. If you are not an Inventor user and have not yet obtained the Inventor Fusion Technology Preview yet, we'd love for you to try the sandbox process. Free Download of Inventor Fusion Technology Preview via Autodesk Labs You can let us know what you think at labs.iv.fusion@autodesk.com. We look forward to your comments. As the sandbox technology preview is new, we'd like to start small. So we are limiting the download of the sandbox to: Australia, Canada, Ireland, New Zealand, Singapore, United Kingdom, and United States. Please note that the Inventor Fusion Technology Preview is still available worldwide. Other locations just use the time-honored full download and full install process. By the way, since the Change Manager add-on for Inventor needs to be installed using the time-honored method, Inventor users should also use the full download and install process to obtain the Inventor Fusion Technology Preview. Trying new ways to deliver technology previews is alive in the lab.
Go to the http://labs.blogs.com/its_alive_in_the_lab/2010/05/inventor-fusion-sandbox-version-now-available.html - original post...
http://labs.blogs.com" rel="nofollow - It's Alive in ihe Lab - Autodesk Labs blog by Scott Sheppard
