Print Page | Close Window
AutoCAD 2011 ~ POP Goes the Material!
Printed From: CAD Forum
Category: EN
Forum Name: RSS Feeds
Forum Description: Automatic publishing of CAD information from other web sources
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3826
Printed Date: 16.Sep.2026 at 09:31
Topic: AutoCAD 2011 ~ POP Goes the Material!
Posted By: BetweenTheLines
Subject: AutoCAD 2011 ~ POP Goes the Material!
Date Posted: 02.Jun.2010 at 15:39
Here is a great tip on http://www.autodesk.com/autocad - AutoCAD 2011 Materials enhancements from my http://www.autodesk.com - Autodesk colleague Randy Young who is the AutoCAD Graphics System QA Lead in the Autodesk http://maps.google.com/maps?f=q&source=s_q&hl=en&q=ONe+Market,+San+Francisco+Autodesk&sll=37.79526,-122.39413&sspn=0.00173,0.003321&ie=UTF8&radius=0.11&split=1&filter=0&rq=1&ev=p&hq=ONe+Market,+San+Francisco+Autodesk&hnear=&ll=37.794186,-122.39487&spn=0.001677,0.003321&t=h&z=19&iwloc=A - San Francisco office .
In AutoCAD 2011 Autodesk has worked to break the myth of AutoCAD being just another 2D application. This year the AutoCAD materials now show bump maps real time in the viewport. This is achieved by enabling The Advance Material effect. The effect is normally enabled by default but if it is not you can enable it by doing the following.
  1. Click on the new GRAPHICSCONFIG button on the status bar.AutoCAD 2011 New GRAPHICSCONFIG Control
    The image above is what the button looks like when you are in hardware acceleration.
    This is what it looks like when it is not enabled. AutoCAD 2011 Hardware Acceleration not enabled
  2. Choose the Performance Tuner… option from the menuAutoCAD 2011 Performance Tuner
  3. Click Manual tune button in the Performance Tuner dialog.AutoCAD 2011 Manual tune button in the Performance Tuner dialog
  4. Now choose on next to ON next to the Advanced material effects name.AutoCAD 2011 Advanced material effects
  5. Enjoy your new rich real time in viewport “rendering like” material display.
Please note that this effect is very graphics card specific and it could cause graphics system slow downs, so if you see any, I would suggest turning the effect off.
AutoCAD 2011 Real time in viewport “rendering like” material display
This is an example of pre-2011 material display with advance material effect turned off.
AutoCAD 2011 Pre-2011 material display with advance material effect turned off.
This is the new AutoCAD 2011 material in viewport with advance material effect on. Pretty cool isn’t it?
<Shaan> “Yes it is cool Randy”
Now imagine how your designs will pop as you are showing your perspective clients what their projects will look like real time in viewport.
Good Luck,
Randy Young
http://feeds.feedburner.com/~ff/blogs/btl?a=fJmvPD1OzB8:W6XCt6PsOsE:yIl2AUoC8zA"> http://feeds.feedburner.com/~ff/blogs/btl?a=fJmvPD1OzB8:W6XCt6PsOsE:qj6IDK7rITs"> http://feeds.feedburner.com/~ff/blogs/btl?a=fJmvPD1OzB8:W6XCt6PsOsE:V_sGLiPBpWU"> http://feeds.feedburner.com/~ff/blogs/btl?a=fJmvPD1OzB8:W6XCt6PsOsE:sHskjighKVI">
Go to the http://feedproxy.google.com/~r/blogs/btl/~3/fJmvPD1OzB8/autocad-2011-pop-goes-the-material.html - original post...
http://autodesk.blogs.com/between_the_lines/" rel="nofollow - Between the Lines - Autodesk blog by Shaan Hurley
