Print Page | Close Window
45 deg hatch gradient
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3836
Printed Date: 03.Sep.2026 at 19:46
Topic: 45 deg hatch gradient
Posted By: peet_dk
Subject: 45 deg hatch gradient
Date Posted: 04.Jun.2010 at 09:47
Hello
Please see the pdf drawing, how can I make a 45 deg hatch so it will look like the one in the red circle? And not the one showed in the full pipe.
http://dl.dropbox.com/u/559096/123.pdf
Posted By: Vladimir Michl
Date Posted: 04.Jun.2010 at 11:34
You will need an add-on utility to make this type of hatch.
Please try the attached LISP tool by M.Jacinto (load it with APPLOAD and start the CYLHATCH command):
http://www.cadforum.cz/forum_en/uploads/20100604_113445_cylhatch.lsp - uploads/20100604_113445_cylhatch.lsp
Vladimir Michl (moderator)
ARKANCE - https://arkance.world" rel="nofollow - https://arkance.world - Autodesk Platinum Partner
Posted By: Tankman
Date Posted: 04.Jun.2010 at 18:30
Nice routine, tried it at your direction.
Thanks for posting it Vladimir!
Tankman
"When the well's dry, we'll all know the value of water."
