Print Page | Close Window
How to put lines in the same level ?
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3878
Printed Date: 06.Sep.2026 at 03:47
Topic: How to put lines in the same level ?
Posted By: jmontesmx
Subject: How to put lines in the same level ?
Date Posted: 16.Jun.2010 at 02:35
When I recieve a project to complete this with electrical or structural designs, sometimes the lines of this doesn't are in the same level, even if the designer that bring me the project doesn't know how to draw in 3D, what can I do to put the lines in the same level to can use the osnap , because in the other form it's so difficult to do it.
I will apreciatte if you can help me to fix this.
Posted By: CarlB
Date Posted: 16.Jun.2010 at 04:45
"Flatten" command will move selected objects/parts of object to zero elevation (z value).
Date Posted: 16.Jun.2010 at 16:49
thanks a lot for your help.
Posted By: GilHuff
Date Posted: 16.Jun.2010 at 18:52
You can also go into the properties dialog box and change the z component of the drawing to 0.  You might have to change the actual z coordinate beginning and end to 0.  Flatten is nice too.
Gilbert Huff
