Print Page | Close Window
LED Lighting plugin?
Printed From: CAD Forum
Category: EN
Forum Name: CAD - general
Forum Description: General discussion about CAD, formats, standards, management, licensing, networking, harware, other CAD applications
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3921
Printed Date: 02.Oct.2026 at 06:19
Topic: LED Lighting plugin?
Posted By: RussellEngland
Subject: LED Lighting plugin?
Date Posted: 26.Jun.2010 at 12:48
Hi there
I'm not a CAD user but have a client who is looking for a CAD application.
They are currently using this software:
http://www.signwizard.com/products/ledwizard.php" rel="nofollow - http://www.signwizard.com/products/ledwizard.php
It autofills a shape with LED lighting modules - connected with electrical wires. This is to give them an idea of how many modules are required.
But it doesn't always get it right unfortunately and takes a long time to sort out.
Is there something similar available? Presumably this will be CAD software with a plug in?
The autofill should work by specifying the size of the LED module (a rectangle) with boundaries and a minimum/maximum length for the connections between LED modules.
Then drawing or modifying lines will fill the line with the required number of LED modules.
Cheers, Russ
Posted By: ThomasNet
Date Posted: 26.Jun.2010 at 18:32
Are they using any other CAD programs?
Search ThomasNet to find manufacturers, distributors and service providers http://www.ThomasNet.com" rel="nofollow - http://www.ThomasNet.com
Date Posted: 27.Jun.2010 at 00:15
Hi Thomas
Thank you for your reply
They aren't using any other CAD programs at the minute
Cheers, Russ
