Print Page | Close Window
Editing multiple dynamic blocks??
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=414
Printed Date: 02.Sep.2026 at 22:40
Topic: Editing multiple dynamic blocks??
Posted By: DragonRacer
Subject: Editing multiple dynamic blocks??
Date Posted: 23.Jan.2008 at 11:51
Hello everybody,
I was wondering if anyone knew how to edit multiple dynamic blocks each containing 6 lines of text.  I need to increase the size of this text and as there are a lot of drawings with a lot of blocks I was wondering if there was a way of doing them all at once rather then just simpley editing the scale of them individually??  I am using AutoCAD 2007 LT
Any help would be greatly appreciated
Mark
Posted By: Vladimir Michl
Date Posted: 23.Jan.2008 at 12:01
Are there multiple block references or multiple block definitions? References (inserts) are updated all at the same time, definitions must be changed individually (in LT you cannot use LISP or VBA to automate things).
Vladimir Michl (moderator)
ARKANCE - https://arkance.world" rel="nofollow - https://arkance.world - Autodesk Platinum Partner
