Print Page | Close Window
Working With AutoCAD Sub Objects in 2D
Printed From: CAD Forum
Category: EN
Forum Name: RSS Feeds
Forum Description: Automatic publishing of CAD information from other web sources
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4238
Printed Date: 16.Sep.2026 at 06:44
Topic: Working With AutoCAD Sub Objects in 2D
Posted By: BetweenTheLines
Subject: Working With AutoCAD Sub Objects in 2D
Date Posted: 25.Aug.2010 at 16:42
If you work intensively in AutoCAD 3D modeling, you probably already familiar with sub object. You can modify objects quickly and easily using vertexes. Gizmo in AutoCAD is very helpful. It is very easy to create 3D models in AutoCAD now. But have you used sub objects in 2D drawing?
http://feeds.feedburner.com/~ff/blogs/btl?a=KIQWCtOJ0b4:cc4Kw9ntEhs:yIl2AUoC8zA"> http://feeds.feedburner.com/~ff/blogs/btl?a=KIQWCtOJ0b4:cc4Kw9ntEhs:qj6IDK7rITs"> http://feeds.feedburner.com/~ff/blogs/btl?a=KIQWCtOJ0b4:cc4Kw9ntEhs:sHskjighKVI">
Go to the http://feedproxy.google.com/~r/blogs/btl/~3/KIQWCtOJ0b4/working-with-autocad-sub-objects-in-2d.html - original post...
http://autodesk.blogs.com/between_the_lines/" rel="nofollow - Between the Lines - Autodesk blog by Shaan Hurley
