Print Page | Close Window
autosnap help cad 2006
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4289
Printed Date: 30.Oct.2026 at 21:55
Topic: autosnap help cad 2006
Posted By: dml157
Subject: autosnap help cad 2006
Date Posted: 02.Sep.2010 at 02:43
I love the autosnap feature but my work computer and home computer seem to have two different settings. At home the autosnap feature seems to connect automatically to an endpoint, but at work with it on i can autosnap to an endpoint or any point desired on a line, curve etc.  I checked the options menu and was unable to find anything helpful. I know there is something very simple im missing here anyone have any ideas?
Posted By: Cad64
Date Posted: 05.Sep.2010 at 17:51
It sounds like at home, your Osnaps are set to snap only to endpoints, but at work, your Osnaps are set to snap to endpoints, intersections, midpoints, etc.
Right click on the OSNAP button along the bottom of your screen and select "Settings". Or just type OSNAP at the command line. In the Settings dialog you will be able to specify which Osnaps you want enabled.
Online Portfolio: http://www.rdeweese.com/" rel="nofollow - http://www.rdeweese.com/
Posted By: Tankman
Date Posted: 06.Sep.2010 at 01:28
How did it work for you?
"Right click on the OSNAP button along the bottom of your screen and select "Settings". Or just type OSNAP at the command line. In the Settings dialog you will be able to specify which Osnaps you want enabled."
Tankman
"When the well's dry, we'll all know the value of water."
