Print Page | Close Window
Line typess
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4349
Printed Date: 07.Sep.2026 at 19:13
Topic: Line typess
Posted By: Saf21
Subject: Line typess
Date Posted: 14.Sep.2010 at 13:39
Hi..
Please help..
I'm using AutoCAD Map 2011 and sometimes when using hidden lines, the lines looks like the scale is set different. when i check the 'LTS' it's all the same.......if i draw two line of the same 'LTS', the dashes is at different distance...........
Thank you...
