Print Page | Close Window
AutoCAD 2011 Subscription Advantage Pack Released including IGES Impor
Printed From: CAD Forum
Category: EN
Forum Name: RSS Feeds
Forum Description: Automatic publishing of CAD information from other web sources
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4526
Printed Date: 16.Sep.2026 at 13:54
Topic: AutoCAD 2011 Subscription Advantage Pack Released including IGES Impor
Posted By: BetweenTheLines
Subject: AutoCAD 2011 Subscription Advantage Pack Released including IGES Impor
Date Posted: 30.Sep.2010 at 14:05
  • The http://www.autodesk.com/autocad - AutoCAD 2011 Subscription Advantage Pack has now been released to http://www.autodesk.com/subscription - Autodesk Subscription customers. Subscription Advantage Packs are where http://www.autodesk.com - Autodesk adds a few features from the next release of AutoCAD for your current version.
AutoCAD 2011 Subscription Advantage Pack Ribbon
We have added the Batch http://www.autodesk.com/dwg - DWG conversion tool in core AutoCAD. Now there is no need to download and install http://www.autodesk.com/trueconvert - AutoCAD TrueView DWG viewer to convert the files. No need to use C:\Program Files\Autodesk\AutoCAD 2011\Help\filesACR\WS1a9193826455f5ffa23ce210c4a30acaf-4b79.htm - eTransmit as a file conversion tool, instead use the purpose built tool for batch conversion of DWG files back and forth between file versions. You can even add a custom conversion setup for converting back to R14 DWG format if that rare occasion ever arises or other custom settings.
  • DWG conversion tool: Streamlining collaboration, the DWG conversion tool enables you to translate DWG files created with AutoCAD, AutoCAD LT®, or other AutoCAD-based applications to any of the following DWG versions: Release 14, 2000, 2004, 2007, and 2010. Convert files in batches to quickly bring older file libraries up to date.
DWG conversion tool dialog Custom conversion settings in the DWG conversion tool
http://autodesk.blogs.com/.a/6a00d8341bfd0c53ef0133f4ba73e6970b-pi">DWG conversion tool dialog http://autodesk.blogs.com/.a/6a00d8341bfd0c53ef013487da0983970c-pi">Custom conversion settings in the DWG conversion tool
It’s Back! http://en.wikipedia.org/wiki/IGES - IGES Import and Export in back in http://www.autodesk.com/autocad - AutoCAD at the request of primarily mechanical and industrial design customers. IGES has not been in AutoCAD since around R12. http://www.autodesk.com/autocadmechanical - AutoCAD Mechanical is where IGES feature has been hiding the whole time. IGES is a common file exchange format in ascii format.
  • IGES import/export: IGES drawing file (.igs) import and export capabilities are now available to AutoCAD software users. For anyone working in 3D, IGES is a common format for sharing files with clients, colleagues, and partners.
3D drawing before Export to IGES 3D drawing after import IGES
http://autodesk.blogs.com/.a/6a00d8341bfd0c53ef013487da09dd970c-pi">3D drawing before Export to IGES http://autodesk.blogs.com/.a/6a00d8341bfd0c53ef0133f4ba7440970b-pi">3D drawing after import IGES
A test drawing with several types of imported IGES entities.
http://www.youtube.com - YouTube videos:
  • http://www.youtube.com/view_play_list?p=6658321FBC75FFED - Autodesk Subscription Advantage Pack 2011 Demos (Playlist)
  • http://www.youtube.com/watch?v=_qk8hxE7K7I - Subscription Advantage Pack Demo: AutoCAD 2011 Products
This Subscription Advantage Pack works with all 2011 AutoCAD-based products, including:
  • http://www.autodesk.com/autocad - AutoCAD® 2011
  • http://www.autodesk.com/autocadarchitecture - AutoCAD Architecture 2011
  • http://www.autodesk.com/autocadmep - AutoCAD MEP   2011
  • http://www.autodesk.com/autocadmechanical - AutoCAD Mechanical 2011
  • http://www.autodesk.com/autocadplant3d - AutoCAD Plant 3D   2011
  • http://www.autodesk.com/autocadpid - AutoCAD P&ID   2011
  • http://www.autodesk.com/civil3d - AutoCAD Civil 3D 2011
  • http://www.autodesk.com/autocadelectrical - AutoCAD Electrical 2011
  • http://www.autodesk.com/ecscad - AutoCAD ecscad 2011
  • http://www.autodesk.com/structuraldetailing - AutoCAD Structural Detailing 2011
  • http://www.autodesk.com/map3d - AutoCAD Map 3D
Convert on folks!
Shaan
http://feeds.feedburner.com/~ff/blogs/btl?a=J6gjylBXFLc:uArg7-Nrqc8:yIl2AUoC8zA"> http://feeds.feedburner.com/~ff/blogs/btl?a=J6gjylBXFLc:uArg7-Nrqc8:qj6IDK7rITs"> http://feeds.feedburner.com/~ff/blogs/btl?a=J6gjylBXFLc:uArg7-Nrqc8:sHskjighKVI">
Go to the http://feedproxy.google.com/~r/blogs/btl/~3/J6gjylBXFLc/autocad-2011-subscription-advantage-pack-released-including-iges-import-and-export-1.html - original post...
http://autodesk.blogs.com/between_the_lines/" rel="nofollow - Between the Lines - Autodesk blog by Shaan Hurley
