Print Page | Close Window
Block Question
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=468
Printed Date: 20.Oct.2026 at 07:55
Topic: Block Question
Posted By: MiniMusikk
Subject: Block Question
Date Posted: 08.Feb.2008 at 09:49
Dear fellow Acad users.
I've got a basic question regaring the use of Blocks. I've made a drawing with 5 instances of the same block, and need to change the colour of just one of them. Is this possible (without breaking the reference to the original block) ?
WBR Stian
Posted By: Mitsubishiman
Date Posted: 12.Feb.2008 at 16:19
In AC 2008 you can edit a block by right clicking on the block and enter a editor where you can pretty much alter anything you want, line color, layer etc.
Posted By: jdvrana
Date Posted: 25.Mar.2008 at 23:01
If you created the block on layer 0, as all blocks should,then change one blocks layer or color.
Jeffrey
Posted By: Vladimir Michl
Date Posted: 26.Mar.2008 at 08:36
...and if you have not - you can redefine it to Layer 0 -- see:
http://www.cadforum.cz/cadforum_en/qaID.asp?tip=2427 - http://www.cadforum.cz/cadforum_en/qaID.asp?tip=2427
Vladimir Michl
//CADs.cz" rel="nofollow - //CADs.cz , https://www.linkedin.com/in/vmichl/" rel="nofollow - LinkedIn
