Print Page | Close Window
AutoCAD 2008 LT Drawing Assoication
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=48
Printed Date: 20.Oct.2026 at 22:16
Topic: AutoCAD 2008 LT Drawing Assoication
Posted By: Shelley
Subject: AutoCAD 2008 LT Drawing Assoication
Date Posted: 14.Aug.2007 at 15:31
I have one install of AutoCAD 2008 Lt that will not associate a .dwg with it. If I open windows explorer and try to open a .dwg it will open a new AutoCAD application every time it does not matter if there is already one open. I have AutoCAD 2005 Lt on the same machine and it does not do this.
Any ideas on what I need to change?
Thank you
Shelley
Posted By: Vladimir Michl
Date Posted: 29.Aug.2007 at 09:27
Please check the SDI variable and the DWG association in the Registry. See tip:
http://www.cadforum.cz/cadforum_en/qaID.asp?tip=2311 - http://www.cadforum.cz/cadforum_en/qaID.asp?tip=2311
Vladimir Michl
//CADs.cz" rel="nofollow - //CADs.cz , https://www.linkedin.com/in/vmichl/" rel="nofollow - LinkedIn
