Print Page | Close Window
3D Air plane (Boeing)
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4865
Printed Date: 22.Oct.2026 at 06:16
Topic: 3D Air plane (Boeing)
Posted By: HIH_new
Subject: 3D Air plane (Boeing)
Date Posted: 30.Nov.2010 at 10:17
Hello freinds
please I would like to know how to start 3D drawing of an boeing Airplane body>>>>>any idea??
thanx
Posted By: Rikky
Date Posted: 30.Nov.2010 at 14:21
To start AutoCAD and draw a line??
How mutch experience do you have? Becease I don't know how mutch detail you would put in that drawing but I can make a plain in 5 minutes but also in 1 month...
Posted By: HIH_new
Date Posted: 03.Dec.2010 at 10:34
Thanks Rikky
I can draw many things with AutoCAD 3D ,but for airplane like Boeing or Airbus, I don't know how to start drawing the external body of the airplane, I don't want detailed drawing
I need the an idea or some tricks to draw this irregular shape of airplane body
Thanks
Posted By: HIH_new
Date Posted: 03.Dec.2010 at 13:01
Thanks Rikky
Thanks
Posted By: tulip3D
Date Posted: 03.Dec.2010 at 17:34
So you having an issue drawing the organic, sweeping curves of the body surface?
Not knowing a dang thing, I would say use your sweep command and lay out each panel like they do when its physically made.
Posted By: Rikky
Date Posted: 07.Dec.2010 at 11:03
draw some 2D shapes (sections) and then use loft to aggregate them. And you have a body... same for the wings.
Good luck..
