Print Page | Close Window
Pop out advice while Autocad 2006 is launching
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4915
Printed Date: 21.Oct.2026 at 19:51
Topic: Pop out advice while Autocad 2006 is launching
Posted By: higbal
Subject: Pop out advice while Autocad 2006 is launching
Date Posted: 07.Dec.2010 at 04:28
Hello Guys,
It would be possible to get some trick to fix an advice that my program pop-out when I start autocad 2006?, It says "Es un código bueno". Some function as the EXPLODE command, is not running well. If I want to explode a block for example, nothing happend. I select the objet, I apply the explode command, but the objetct stills unexploded.
Thank a lot for your help.
Best regards,
Higbal
Posted By: HAWDesigner
Date Posted: 13.Dec.2010 at 22:54
Some objects cannot be exploded. Blocks, for instance, cannot be exploded if the 'Allow exploding' Behavior option is unchecked prior to creating the block.
Arcs, lines, and dtext are other examples of items that cannot be exploded.
If it is a block that you're trying to explode, you may be able to change the 'Allow Editing' value by editing the block (Command: BEDIT). Once you have changed that value, and saved the block, then you can try to explode it.
Good Luck!!
R. Williams
AutoCAD 2010 Certified Professional
<!-- If all else fails hit F1 -->
<<AutoCAD 2009
Posted By: Cad64
Date Posted: 14.Dec.2010 at 07:17
Es un código bueno = It's a good code
That's the message that displays when you try to start Autocad?
It sounds like you may have one of the Autocad viruses.
See here for information:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13717811&linkID=9240617" rel="nofollow - http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13717811&linkID=9240617
http://forums.autodesk.com/t5/AutoCAD-2008/Virus-using-acad-fas/td-p/2220982" rel="nofollow - http://forums.autodesk.com/t5/AutoCAD-2008/Virus-using-acad-fas/td-p/2220982
Online Portfolio: http://www.rdeweese.com/" rel="nofollow - http://www.rdeweese.com/
Posted By: higbal
Date Posted: 05.Jan.2011 at 17:50
Thanks a lot for your answering,
we found yesterday some information in order to eliminate this virus using a tool named OTMoveIT. Before to use it, the recommendation was to carry on a complete scan with ActriveScan 2.0 by Panda security in order to identify all location were the virus was allocated. Then using the mentionef tool we could remove that virus. The autocad is running well by now. If somebody needs to fix this trouble I can send you the procedure to solve it.
Thanks for your interesting.
Higbal
Posted By: higbal
Date Posted: 05.Jan.2011 at 17:51
Good Luck!!
Higbal
