Print Page | Close Window
Plot Scale List
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5101
Printed Date: 05.Sep.2026 at 02:24
Topic: Plot Scale List
Posted By: meredith610
Subject: Plot Scale List
Date Posted: 10.Jan.2011 at 18:49
I do civil/land planning in ACAD Map.  Usually, when I go to plot, I have a list of engineering plot scales (i.e. 1"=40', 1"=50'. etc.).  I have a file from an architect in which I have scaled the linework and have everything to scale for feet.  In units, I have the type as decimal and the units as unitless.  When I go to plot, it gives me a list of architectural scales (i.e. 1"=1', etc.).  Does anyone know how I can change the plot scale list from architectural to engineering?  I know I can add/edit using the "scalelistedit" command, but I was looking for a broader application.  Any advice?  Thanks!
Posted By: Vladimir Michl
Date Posted: 10.Jan.2011 at 20:53
You can use the commandline version of the command [CMD]-SCALELISTEDIT[/CMD] to automate the scale list management via a script or a menu macro.
Vladimir Michl (moderator)
https://www.linkedin.com/in/vmichl/" rel="nofollow - LinkedIn , Autodesk Expert Elite
Posted By: HAWDesigner
Date Posted: 10.Jan.2011 at 23:57
That was going to be my suggestion too. The only other suggestion I would have is to write a LISP routine to do it all for you - which really wouldn't be too difficult.
Good Luck!!
R. Williams
AutoCAD 2010 Certified Professional
<!-- If all else fails hit F1 -->
<<AutoCAD 2009
