Print Page | Close Window
Importing into Mechanical 2004
Printed From: CAD Forum
Category: EN
Forum Name: CAD - general
Forum Description: General discussion about CAD, formats, standards, management, licensing, networking, harware, other CAD applications
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5176
Printed Date: 30.Sep.2026 at 11:38
Topic: Importing into Mechanical 2004
Posted By: mchilds
Subject: Importing into Mechanical 2004
Date Posted: 24.Jan.2011 at 15:42
I downloaded a 3d block off of this site to insert into a 3d drawing i am working in AutoCAD Mech 2004.
Error: dwg is invalid???
I am thinking the 3d model is a of a later version of AutoCAD and maybe that is the problem. Not certian.
In any case if anyone has a work around or can think of what i am doing wrong would be great to know.
Thx.
M Childs
Posted By: HAWDesigner
Date Posted: 24.Jan.2011 at 16:46
Most likely the issue is that the block was created with a newer version of AutoCAD.
Go to the following link and download Autodesk's DWG True View. In that program you can convert the DWG file (the block) to earlier versions of AutoCAD.
http://usa.autodesk.com/adsk/servlet/pc/index?id=6703438&siteID=123112" rel="nofollow - http://usa.autodesk.com/adsk/servlet/pc/index?id=6703438&siteID=123112
Good Luck!!
R. Williams
AutoCAD 2010 Certified Professional
<!-- If all else fails hit F1 -->
<<AutoCAD 2009
