layer properties manager "search for layers"
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5298
Printed Date: 06.Sep.2026 at 03:47
Topic: layer properties manager "search for layers"
Posted By: Macieto
Subject: layer properties manager "search for layers"
Date Posted: 11.Feb.2011 at 08:27
Hi,
When you open layer properties manager than in right top corner there is a very usefull box "search for layer". Unfortunatelly that box search only in names of layers and what if I want to search in descriptions of layers?
Do you know any way to search for the phrase in description on layer?
------------- ACAD MEP 2009 EN SP3
Posted By: HAWDesigner
Date Posted: 11.Feb.2011 at 15:42
Sorry, there is no way that I know of (at least in 2009 or earlier). All you can do with the descriptions is sort them by clicking on the title bar.
R. Williams
AutoCAD 2010 Certified Professional
<!-- If all else fails hit F1 -->
<<AutoCAD 2009
Posted By: Vladimir Michl
Date Posted: 11.Feb.2011 at 16:10
No, this is not possible in the layer dialog, nor in the layer filters.
------------- Vladimir Michl (moderator) https://www.linkedin.com/in/vmichl/" rel="nofollow - LinkedIn , Autodesk Expert Elite
Date Posted: 11.Feb.2011 at 16:45
It probably wouldn't be a bad idea to add this to the AutoCAD 2012 wishlist. I'm still reading through the many current responses to the thread below, but I don't see it yet.
http://forums.autodesk.com/t5/AutoCAD-2011/Your-1-wish-for-Acad2012/m-p/2898064#M10903" rel="nofollow - http://forums.autodesk.com/t5/AutoCAD-2011/Your-1-wish-for-Acad2012/m-p/2898064#M10903
R. Williams
<<AutoCAD 2009
Date Posted: 11.Feb.2011 at 16:51
Maybe rather 2013 - the function set for AutoCAD 2012 is frozen already as this version is near to release.
Date Posted: 11.Feb.2011 at 17:02
Very true. I can hardly wait to get my hands on 2012. (We upgrade every 3 years here)
R. Williams
<<AutoCAD 2009
Posted By: Macieto
Date Posted: 12.Feb.2011 at 10:19
oh thats a pity....... But this is good initiative by You member_profile.asp?PF=16131&FID=2" rel="nofollow - HAWDesigner
The problem with searching through layer descriptions occurs when layer names are made according to some company standard using acronims etc, and you are not able to search for the apriopriate phrase in it. Then if there is any description for layers you can find what you want if you will have tool for searching in descriptions
thanks
