Print Page | Close Window
Dimensioning
Printed From: CAD Forum
Category: EN
Forum Name: CAD - general
Forum Description: General discussion about CAD, formats, standards, management, licensing, networking, harware, other CAD applications
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5368
Printed Date: 02.Oct.2026 at 02:37
Topic: Dimensioning
Posted By: manich44
Subject: Dimensioning
Date Posted: 24.Feb.2011 at 20:25
Hi,
I am new to autocad so just finding my way around at the moment.I would like to know how to change the dimension arrows from the inside of a column to the outside ie one either side of the column pointing towards each other when using linear dimensioning.
Also where do I find an arrow which I can use just to point at a component and then ad text about it?
Any Advice much appreciated
MarkConfused
Posted By: HAWDesigner
Date Posted: 24.Feb.2011 at 20:36
All of your Dimension settings can be found in the Dimension Style Manager
Command: [CMD]DIMSTYLE[/CMD]
The settings you're looking for will be on the Fit tab.
To answer your 2nd question, you can use the [CMD]LEADER[/CMD] command or look in the Multileaders area of your Annotate ribbon.
Good Luck!!
R. Williams
AutoCAD 2010 Certified Professional
<!-- If all else fails hit F1 -->
<<AutoCAD 2009
Posted By: manich44
Date Posted: 25.Feb.2011 at 12:44
That did it!
Thanks...Clap
Date Posted: 25.Feb.2011 at 14:04
You're welcome!! If you need anything else, we're always here.Cool
R. Williams
<<AutoCAD 2009
