Print Page | Close Window
pipe bend surface area calculation in autocad
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5369
Printed Date: 28.Oct.2026 at 21:55
Topic: pipe bend surface area calculation in autocad
Posted By: spanatko
Subject: pipe bend surface area calculation in autocad
Date Posted: 25.Feb.2011 at 00:07
Hello,
I need a hint on calculating the surface area of a pipe bend /to be more precise of the bends individual sections/, is this possible to do in autocad with 3d? is there such a library of functions? any suggestions or information appreciated.
Big thanks
Mike
Posted By: CarlB
Date Posted: 25.Feb.2011 at 01:14
Assuming consistent circular cross-section, the surface area is the pipe circumference times the centerline length.
If bent on curve of radius R, the centerline length is R x Bend angle (in radians).
A pipe of outer radius r, at a 45 degree bend would have length  R x 45 x (Pi/180), and a surface area of (2Pi x r)x (R x Pi/4)
That geometric method seems easier than a cad solution.
http://en.wikipedia.org/wiki/Torus" rel="nofollow - http://en.wikipedia.org/wiki/Torus
Posted By: spanatko
Date Posted: 25.Feb.2011 at 08:49
Hello,
thank you very much for your input and explanation, a cad solution will be required here as the sections of the bend will have to be manufactured based on some graphic presentation. I assume it will be in 3d, but what I do not know is the module that I need to buy to be able to calculate /and depict/ the surface areas  and shapes for the individual sections in the pipe bend.
So far I have found 2 candidates /AutoCad plant 3D and Autocad P&ID/ but I might be very wrong here, and maybe some other version might be totally suitable for these calculations and imagery. Thank you for the geometric method description as well, I am looking at it right now and it helps.
Thank you & Regards
Michael
< ="content-" content="text/; charset=utf-8">< ="content-" content="text/; charset=utf-8">
Posted By: John Connor
Date Posted: 25.Feb.2011 at 11:46
I think AutoDesk Inventor might be a better choice.
<<AutoCAD 2015>>
