Print Page | Close Window
Hatch Problems
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5494
Printed Date: 05.Sep.2026 at 07:08
Topic: Hatch Problems
Posted By: kcrismon
Subject: Hatch Problems
Date Posted: 17.Mar.2011 at 18:05
Hello everyone,
I've been searching all morning for an answer to my problem, but I can't seem to find anything about it. I'm using AutoCAD 2010's hatch feature to apply colors under large zones on a floor plan. The hatching slows down my computer significantly, but I turn that layer off after I hatch to eliminate the problem. The problem is that when I export my drawings to a pdf file the file is very slow. It takes awhile for the pdf to load, and then the file has to rerender each time i hit the zoom button. It makes looking at the file extremely difficult. Has anyone had this problem before or does anyone have any ideas for a solution???
Posted By: CarlB
Date Posted: 18.Mar.2011 at 02:36
To speed up a drawing, freezing should work better than turning off layers. Maybe that will improve the PDF size/performance. How are you creating pdf's? Don't know what "export to" is.
Posted By: malvar
Date Posted: 18.Mar.2011 at 03:18
Have you tried to open the PDF file in Acrobat and reduce the file size? You can do this by clicking on Document tab then the Reduce File Size option. Save the file in another file name and compare the file sizes by looking at its property. It may also help if you save the file with the Fast Web View through the PDF optimizer found in Advanced tool tab.
Posted By: Cad64
Date Posted: 18.Mar.2011 at 07:26
What type of hatch pattern are you using? Some patterns can cause problems, especially if you have the scale set to create a very dense pattern. If you're not already doing so, try using the solid color hatch.
Online Portfolio: http://www.rdeweese.com/" rel="nofollow - http://www.rdeweese.com/
Posted By: kcrismon
Date Posted: 18.Mar.2011 at 21:40
Thanks for the help everyone. I had a very dense line pattern on my hatch to form a solid. I changed that to a solid pattern and the problem went away instantly. I'm fairly new to autoCAD and was told to use the dense line pattern to make solids, but the solid pattern is clearly the better way to go. Thanks again for the help. I'll definately come back to this website for any other questions that I might have.
