Finishing Data Extraction Error
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5498
Printed Date: 22.Oct.2026 at 01:07
Topic: Finishing Data Extraction Error
Posted By: RMCGARRIE
Subject: Finishing Data Extraction Error
Date Posted: 18.Mar.2011 at 10:36
hi all
i have run a data extraction and managed to get through all the section until i get to the last one where you have to select target forlder to save and finish but before i can do this a warning comes see ,below....
"Application does not support just-in-time (JIT)
debugging. "
can anybody shed some light on how to resolve this
cheers
r
Posted By: John Connor
Date Posted: 18.Mar.2011 at 11:02
Which program were you using at the time when the error message appeared?
What version of Windows are you using?
I've read two conflicting views regarding "JIT" errors. One says it is a Windows problem and something to do with security settings. The other says it has something to do with the Communications Center. Still searching for a definitive answer. If I find one I'll post a link to it.
Sorry I cannot solve your problem for you at this time.
------------- "Humans have a strength that cannot be measured. This is John Connor. If you are reading this, you are the resistance."
<<AutoCAD 2015>>
Date Posted: 18.Mar.2011 at 11:06
just running a small dwg on autocad 2011, only running cad on my windows at the time.looking into my network to see if it is a windows problem or not. no worrys cheers for having a go though
r
------------- ryan mcgarrie CAD OP
