Having problems with TEXT
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5517
Printed Date: 04.Sep.2026 at 17:34
Topic: Having problems with TEXT
Posted By: maki21
Subject: Having problems with TEXT
Date Posted: 21.Mar.2011 at 13:54
Hy!
I have a bit strange problem with my autocad 2011. Since i am new to it, this might be a beginer mistake, but i was searching for answer and google can not find it, so...
When i try to create text (multiline, single line doesn`t really matter), i pick font, size and everything smoothly, and than type it, still ok. When i want to finish it, it goes away and there is some strange line created. There is no text left, only doted line or not even a line, just spot...
When i type my text it looks like this: http://www.shrani.si/?w/XI/2wxcs5K8/autocad-problems1.jpg" rel="nofollow">
and than... http://www.shrani.si/?1P/ra/tpyfmOe/autocad-problems.png" rel="nofollow">
Can someone tells me what i did wrong in options or anywhere? Thank you,
best regards,
Maki21
Posted By: xikes
Date Posted: 21.Mar.2011 at 14:05
Try to zoom in. It's possible, that you text height is too small to display.
Posted By: maki21
Date Posted: 21.Mar.2011 at 14:12
I tryed everything what i knew it could be wrong but nothing helped... I can zoom in how much i want it is still only spot or line.
Posted By: xikes
Date Posted: 21.Mar.2011 at 14:25
Try to change the text style. Or edit the style you have selected for that text (Standard). Try changing the font and height.
Posted By: John Connor
Date Posted: 21.Mar.2011 at 14:30
Are you working in model space or a paper space layout?
What units are you working in?
What is the height of your text set at?
------------- "Humans have a strength that cannot be measured. This is John Connor. If you are reading this, you are the resistance."
<<AutoCAD 2015>>
Posted By: maki21
Date Posted: 21.Mar.2011 at 15:05
I am working in a model space layout, units are centimetrs, text height is set at 1, if i am looking at the right number...
Date Posted: 21.Mar.2011 at 16:07
Just for the fun of it change the 1 to 100 and see what, if anything, happens in your drawing.
<<AutoCAD 2015>>
Posted By: maki21
Date Posted: 21.Mar.2011 at 16:13
Nope, everything remains the same...
Date Posted: 21.Mar.2011 at 19:12
Post the drawing and let someone here take a look at it.
<<AutoCAD 2015>>
Posted By: maki21
Date Posted: 21.Mar.2011 at 22:30
What do you mean? To paste the whole autocad file as attachment? or what? Or just a print screen?
Date Posted: 22.Mar.2011 at 10:46
Post the dwg file itself.
<<AutoCAD 2015>>
