Print Page | Close Window
Blocks automatic scaling
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5534
Printed Date: 19.Oct.2026 at 06:55
Topic: Blocks automatic scaling
Posted By: samifox
Subject: Blocks automatic scaling
Date Posted: 22.Mar.2011 at 13:31
Hi
im using LT 2008.
im a drafter for construction. in my daly workflow im placing blocks in the corner and intersection of the walls.  most of the time block do not fit the the intersection or the corner since the different wall thikness .
for example ,  20cm wall intersecting with 40cm wall, so i dont have any choise than exploding the block and fine tune it manualy.
is there a way the block can fit itself automatically?
hope i explain myself well
(i would upload an image but i cant the upload button is not there or the site doesnt accept links for free hosting image services).
Thanks
Shay
Posted By: John Connor
Date Posted: 22.Mar.2011 at 13:44
Try using Dynamic Blocks rather than regular blocks.
<<AutoCAD 2015>>
Posted By: samifox
Date Posted: 23.Mar.2011 at 02:18
ClapClapClap small step for John Connor , big step for Shay ClapClapClap
Thanks  a milion John! it realy going to save me helf day of work!!! cuz of you i can spend more time with friends and family.
Thanks again,
Shay
Posted By: Cadman11
Date Posted: 23.Mar.2011 at 20:17
Samifox-
Adding geometric and dimensional constraints is certainly the way to go on that, so now to resize the blocks you will not have to explode the blocks but will pull and push them to fit where ever
Cadman
