http://autodesk.blogs.com/.a/6a00d8341bfd0c53ef0147e3644e54970b-pi"> The http://www.autodesk.com/autocad - AutoCAD 2012 Splash image is a rendering of backstage robotic video screens for the latest rock concert tour by Bon Jovi. AutoCAD and Autodesk 3ds Max software products were used in the design process. Image courtesy of Tait Towers, Inc. The splash image sets the tone as this release rocks! http://www.autodesk.com/autocad - AutoCAD 2012 Preview Guide http://bit.ly/gFJHQR - http://bit.ly/gFJHQR And so here we have AutoCAD 2012 also known as codename “Ironman” launched and showing the new Autodesk Exchange. http://autodesk.blogs.com/.a/6a00d8341bfd0c53ef0147e3638319970b-pi"> AutoCAD 2012 uses the AutoCAD 2010 Drawing file format used by AutoCAD 2010, AutoCAD 20111 and now used by AutoCAD 2012. Here are my top ten of the highlights in no particular order #1 Performance This release of http://www.autodesk.com/autocad - AutoCAD is speedy and was noticed by pre-release beta testers as launching and running faster. #2 Associative Array With AutoCAD 2012 you can now array in 2D and 3D based on polar, rectangular, and path and associate the arrayed objects. There is a preview of the array in-process so you can refine what you want before committing to the settings. http://autodesk.blogs.com/.a/6a00d8341bfd0c53ef014e60098da2970c-pi"> Since the array objects are associated to the path I created, when I edit the path the arrayed objects follow. http://autodesk.blogs.com/.a/6a00d8341bfd0c53ef014e86e47d05970d-pi">
#3 Autodesk Inventor Fusion http://www.autodesk.com - Autodesk Fusion is an optional installation. Autodesk Inventor Fusion is an application for easily editing 3D models with direct modeling for easy creation and editing of models. The option to edit model from AutoCAD in Fusion is available in the ribbon on the Plug-ins tab, the EDITINFUSION command or by launching it as a standalone session from the Windows Start>Autodesk>Autodesk Inventor Fusion. Autodesk Inventor Fusion is a recent graduate of http://labs.autodesk.com/ - Autodesk Labs where it was on the honor roll. #4 Model Documentation With AutoCAD 2012 you can now import several file 3D formats for documenting models such as CATIA®, NX®, Parasolid, Pro/Engineer®, Rhinoceros®, NX, and SolidWorks®. You can place base views and projected views in various display styles such as hidden wireframe, shaded, etc. You can also update the views when the parent file changes. http://autodesk.blogs.com/.a/6a00d8341bfd0c53ef014e60098dc0970c-pi">
#5 Nudge You can now move selected objects orthogonally a few pixels at a time by using CTRL and the arrow keys.
#6 Multifunctional Grips
http://autodesk.blogs.com/.a/6a00d8341bfd0c53ef0147e3644e82970b-pi"> There is now more objects that provide more options when you hover over the grip of a selected object. Some of the new supported objects are lines, arc, elliptical arcs, dimensions, 3D faces and more. Access to options for an object simply by hovering over a grip speeds up design and documentation. #7 In-Canvas Viewport Control
http://autodesk.blogs.com/.a/6a00d8341bfd0c53ef014e60098dda970c-pi"> Just like in http://www.autodesk.com/autocadformac - AutoCAD for Mac and 3ds max, you can now change views and visual styles in the viewport using the small menu in the upper left corner of the drawing window.. #8 Content Explorer
http://autodesk.blogs.com/.a/6a00d8341bfd0c53ef0147e3644e8b970b-pi"> This feature was previously known as http://labs.autodesk.com/utilities/snap/ - Project Snap and is another http://labs.autodesk.com/ - Autodesk Labs graduate included in AutoCAD 2012. Think of Content Explorer like a more powerful Design Center. You can search or browse for content in the drawing or other files on your machine or network. #9 AutoComplete Command Entry
http://autodesk.blogs.com/.a/6a00d8341bfd0c53ef014e86e47d3b970d-pi"> This is a sweet feature but I am still awaiting a “Thought AutoComplete” feature. when you start typing a command either at the command line or the dynamic input you will get some options for the possible command or system variable you are entering saving you time. AutoCAD WS is now included in the product with commands and menus for uploading, downloading, and sharing your files on the free AutoCAD WS web service. With AutoCAD WS you have nothing to install as it is available in the web browser. There is also the free http://www.itunes.com/app/autocad-ws - AutoCAD WS Mobile which is currently available in the http://www.apple.com - Apple app store for http://en.wikipedia.org/wiki/IOS_(Apple) - iOS devices such as http://www.apple.com/ipodtouch/ - iPod Touch , http://www.apple.com/iphone - iPhone , and the http://www.apple.com/ipad - iPad devices. You can view, markup, and edit the drawing files placed on AutoCAD WS and in the AutoCAD WS Mobile you can synch your files offline for carrying all your design files on your mobile device to the job site. There is much more under the hood and I invite you to take a test drive and kick the tires. http://usa.autodesk.com/autocad/trial/ - http://usa.autodesk.com/autocad/trial/ What are your top ten? Cheers, Shaan
http://feeds.feedburner.com/~ff/blogs/btl?a=dosHrxMsiTw:xCb9G1ldiuM:yIl2AUoC8zA">  http://feeds.feedburner.com/~ff/blogs/btl?a=dosHrxMsiTw:xCb9G1ldiuM:qj6IDK7rITs">  http://feeds.feedburner.com/~ff/blogs/btl?a=dosHrxMsiTw:xCb9G1ldiuM:sHskjighKVI">
 Go to the http://feedproxy.google.com/~r/blogs/btl/~3/dosHrxMsiTw/autocad-2012-and-autocad-2012-announced.html - original post...
------------- http://autodesk.blogs.com/between_the_lines/" rel="nofollow - Between the Lines - Autodesk blog by Shaan Hurley
