Parametric relationship
Printed From: CAD Forum
Category: EN
Forum Name: 3ds Max, Maya, VRED
Forum Description: Discussion about Autodesk rendering and multimedia software, Max, Maya, VRED, Autodesk Flow platform
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5588
Printed Date: 10.Oct.2026 at 02:26
Topic: Parametric relationship
Posted By: rendermen
Subject: Parametric relationship
Date Posted: 27.Mar.2011 at 18:01
Often times I need to alter my model in Inventor which import into 3ds max. Is there a way to update my model in 3ds with the updated file yet maintain my bitmap assignments? Thank you!
------------- Renderman
Posted By: Cad64
Date Posted: 27.Mar.2011 at 19:03
Why do you need to alter your model in Inventor? What are you building that can't be worked on in Max?
Once you take your model out of Max and edit it in another program you will have to redo your UVW mapping and re-apply your materials when you bring the model back in.
Just edit the model in Max. You're making things more difficult than they need to be.
------------- Online Portfolio: http://www.rdeweese.com/" rel="nofollow - http://www.rdeweese.com/
