Print Page | Close Window
Optimizing PDF performance in ACAD2010
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5607
Printed Date: 05.Sep.2026 at 22:06
Topic: Optimizing PDF performance in ACAD2010
Posted By: orien87
Subject: Optimizing PDF performance in ACAD2010
Date Posted: 29.Mar.2011 at 15:31
Hi,
New to the site. I searched for answers but did not find anything helpful. Now I'm here.
Is there a way to optimize the way AutoCAD 2010 handles large PDFs. My system just bogs down to a craw when using scanned PDFs that consume memory. Maybe there is a setting that will speed the process of pan and zoom to a more manageable level.
Thanks
Posted By: Vladimir Michl
Date Posted: 29.Mar.2011 at 16:03
The graphics card (faster, with more VRAM) may help to some level. Otherwise you might use a lower dpi for your scanned PDFs.
Vladimir Michl (moderator)
https://www.linkedin.com/in/vmichl/" rel="nofollow - LinkedIn , Autodesk Expert Elite
Posted By: orien87
Date Posted: 31.Mar.2011 at 18:35
I don't think I need a new card, because I use Bluebleam to edit and use pdfs and it’s all good. Seriously Bluebeam is so much better at rendering the same file than AutoCAD2010.
I'm hoping there’s a way to tell CAD10 through a system variable to only render the file after I'm done panning/zooming. Thus increasing productivity at work
Posted By: John Connor
Date Posted: 31.Mar.2011 at 23:29
Are you on Subscription?
<<AutoCAD 2015>>
Posted By: Cad64
Date Posted: 01.Apr.2011 at 06:02
You can disable automatic regeneration with the REGENAUTO command.
On - Regenerates the drawing immediately if any suppressed regenerations exist in the queue and continues to regenerate automatically whenever you perform an action that requires regeneration.
Off - Inhibits regeneration of the drawing until you use the REGEN or REGENALL command.
Online Portfolio: http://www.rdeweese.com/" rel="nofollow - http://www.rdeweese.com/
