Print Page | Close Window
Convert Radan (.DRG) files to AutoCAD files
Printed From: CAD Forum
Category: EN
Forum Name: CAD - general
Forum Description: General discussion about CAD, formats, standards, management, licensing, networking, harware, other CAD applications
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5695
Printed Date: 03.Oct.2026 at 00:19
Topic: Convert Radan (.DRG) files to AutoCAD files
Posted By: 1cainr
Subject: Convert Radan (.DRG) files to AutoCAD files
Date Posted: 14.Apr.2011 at 13:39
Hello,
Does anyone know the best way to convert .drg files to a file format which AutoCAD can read (.DXF, .DWG)? P.s. i still need the functionality to edit the drawings when needed.
When I export from Radan it uses only one pen colour in the DXF, and not the colours set in the Radan drawing.
Thanks,
Posted By: John Connor
Date Posted: 14.Apr.2011 at 16:09
I don't know of any DRG -to-DWG converters.
Why must you edit the drawings in a different program?
<<AutoCAD 2015>>
Posted By: 1cainr
Date Posted: 14.Apr.2011 at 16:57
Radraft creates the DRG files, and we are replacing Radraft with AutoCAD.
AutoCAD cannot open DRG files and we want to convert all the files to an AutoCAD file type so we can use them.
A user may open up one of the old drawings and want to change a piece of text or something like that.
Date Posted: 14.Apr.2011 at 18:21
And you cannot use a DXF because of the one pen colour as you mentioned.  Seems like you are stuck.
<<AutoCAD 2015>>
Posted By: 1cainr
Date Posted: 15.Apr.2011 at 09:19
Yep im stuck, this is why i left a post, i hoped someone on here had the answer :-(
