Print Page | Close Window
PDF to AutoCAD
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5850
Printed Date: 05.Sep.2026 at 00:02
Topic: PDF to AutoCAD
Posted By: teafoe5
Subject: PDF to AutoCAD
Date Posted: 09.May.2011 at 16:52
I am creating a standards booklet with all of my offices standard details in PDF.  How can I make it so that once the detail is in PDF form all I have to do is click on the drawing in the PDF and it will open up in AutoCAD?  I know this is possible as my last firm did it but I cannot figure out how.
Posted By: FAYYAZ
Date Posted: 09.May.2011 at 18:55
Posted By: heinsite
Date Posted: 11.May.2011 at 04:24
I'm guessing here, but the first thing I'd try would be to see if it's possible to set up a hyperlink in the PDF using Adobe Acrobat.
Dave Hein, P.E.
Hawaii District Engineer
Kona International Airport
AutoCAD Certified Professional
Posted By: dabrovsky
Date Posted: 11.May.2011 at 10:24
attache pdf the same way as you do with xref
Posted By: heinsite
Date Posted: 11.May.2011 at 21:18
I think what the OP is trying to do here is create a PDF that will open a specific DWG.  That work is outside the scope of AutoCAD.
Dave Hein, P.E.
