editing world blocks
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5855
Printed Date: 20.Oct.2026 at 05:27
Topic: editing world blocks
Posted By: briguy
Subject: editing world blocks
Date Posted: 09.May.2011 at 21:37
I have portions of one drawing that i would like to insert into another drawing (as a world block) but also have to the ability to edit that world block after it is inserted. For example i took a portion of a floor plan from one drawing, saved it as a world block to allow me to insert it into another drawing. After i did this i wanted to remove portions of this world block but it is not possible to "explode" a world block, what am i missing??< id="gwProxy" ="">< ="jsCall();" id="jsProxy" ="">
Posted By: John Connor
Date Posted: 09.May.2011 at 23:48
A World Block? Do you mean a WBlock? WBlock stands for Write Block. It describes what AutoCAD does when you save a block to your hard drive rather than in the drawing it was created in using the Block command.
Blocks can generally be exploded unless they were inserted with different X/Y values. Or, maybe you have a nested block and you have to explode it more than once.
------------- "Humans have a strength that cannot be measured. This is John Connor. If you are reading this, you are the resistance."
<<AutoCAD 2015>>
Posted By: briguy
Date Posted: 10.May.2011 at 20:59
I am trying to create a world block so i can use it in other drawings, but i haven't figured that out yet. You are right, i was using the wblock. I know if i just create a regular block then it is not available in other drawings, correct?< id="gwProxy" ="">< ="jsCall();" id="jsProxy" ="">
Date Posted: 10.May.2011 at 23:54
I have not heard of the term "World Block". You'll have to explain to me what the difference between a World Block and a WBlock is.
Blocks created in individual drawings can still be accessed by way of the Design Center so technically you do not have to use WBlock.
<<AutoCAD 2015>>
