Print Page | Close Window
How Add Arabic Text in 3ds MAX
Printed From: CAD Forum
Category: EN
Forum Name: 3ds Max, Maya, VRED
Forum Description: Discussion about Autodesk rendering and multimedia software, Max, Maya, VRED, Autodesk Flow platform
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5936
Printed Date: 10.Oct.2026 at 05:46
Topic: How Add Arabic Text in 3ds MAX
Posted By: heartscool
Subject: How Add Arabic Text in 3ds MAX
Date Posted: 21.May.2011 at 15:27
Hi, any idea how to add arabic text in 3ds max 2009 ? please suggest, thanks.
Cool Heart Models
http://www.all3dmodel.com
Posted By: Brown11
Date Posted: 11.Aug.2011 at 06:37
"Use Text to create splines in the shape of text.
The text can use any Windows font installed on your system, or a Type 1 PostScript font installed in the directory pointed to by the Fonts path on the Configure System Paths dialog. Because fonts are loaded only at first use, changing the font path later has no immediate effect: once you have used the font manager, you must restart 3ds Max before you can use a new font path."
Brown11
Posted By: rongosh
Date Posted: 29.Nov.2011 at 07:27
Go to Help-> Autodesk 3ds max help
