Print Page | Close Window
Block scale
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6047
Printed Date: 24.Oct.2026 at 15:10
Topic: Block scale
Posted By: 2slim
Subject: Block scale
Date Posted: 09.Jun.2011 at 20:52
When I insert a block into a 2D drawing from the block library the scale is different from the other blocks in the drawing. I have not changed the drawing scale and remember the blocks working properly a month or so back. The blocks are "read only" and on a network server so I can't change the scale of the block individually. I must have changed some setting on AutoCAD 2007 on my computer. Any ideas?
Todd (2slim)
2slim
Posted By: philippe JOSEPH
Date Posted: 10.Jun.2011 at 11:18
The problem must be with the "insertion scale" set in the different files.
See "DDUNITS" + "INSERTION SCALE" THAT CAN BE SET TO :
WITHOUT UNITS, FEET, INCHE, MILE, MILLIMETER, ETC...
Normaly that should lead to no problems with different drawing units but when you mix old drawings without possibilities of "insertion scale" to set in the "DDUNITS" you have to rescale the objects after insertion.
Posted By: Vladimir Michl
Date Posted: 10.Jun.2011 at 11:33
See also the tip:
http://www.cadforum.cz/cadforum_en/qaID.asp?tip=4581 - http://www.cadforum.cz/cadforum_en/qaID.asp?tip=4581
Vladimir Michl
//CADs.cz" rel="nofollow - //CADs.cz , https://www.linkedin.com/in/vmichl/" rel="nofollow - LinkedIn
Posted By: titashtalukdar
Date Posted: 14.Jun.2011 at 08:20
In DDUNITS try & use the UNITS not as unitless but maybe the scale in which you are working
ar.titashtalukdar
