Help changing lable size on contours
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6082
Printed Date: 05.Sep.2026 at 16:05
Topic: Help changing lable size on contours
Posted By: pdrls
Subject: Help changing lable size on contours
Date Posted: 15.Jun.2011 at 03:28
I can type in any hieght at the "Contour style manager" and it does not change the size of my lables? I'm using Desktop 2005. Any help would be greatly appreciated. Thanks in advanced.
Posted By: John Connor
Date Posted: 15.Jun.2011 at 12:33
Could it be that the text height has been preset using the Style command?
------------- "Humans have a strength that cannot be measured. This is John Connor. If you are reading this, you are the resistance."
<<AutoCAD 2015>>
Posted By: pdrls
Date Posted: 15.Jun.2011 at 14:48
Thank you John for your responce. I figured it out sort of. I was using "standard" for the text style and it would alow me to type in a hieght yet it did not change. If i choose L140 or L500 the hieght is fixed yet L140 fits my needs so I'll go with that for now. Is there a text style that works better in labling contours that is sizable? Thanks again.
Posted By: alanjt
Date Posted: 15.Jun.2011 at 15:05
If your style has a height (other than zero), you will not be able to alter the size from the contour label manager. You'll either have to choose to use a style with a set value of zero or alter the style.
Date Posted: 15.Jun.2011 at 19:04
You can go back into the Style command and reset the fixed height to "0" for styles L140 and L500.
<<AutoCAD 2015>>
